FLUKA:4-5.1 (gfor>=9)
Flair:3.4-5
Operating system:Ubuntu 24.04.1 LTS (Windows 11 WSL)
Hello,
I am trying to import an MCNP file into Flair, but I am encountering a Python error.
Actions Taken:
Open Flair.
Go to
File→Import→MCNP...Select my MCNP input file.
Result: The import fails, and the following error appears in the terminal:
File “/usr/local/flair/tkFlair.py”, line 1557, in call
return self.func(*args)
File “/usr/local/flair/flair.py”, line 1575, in importMcnp
self.project.input = self._convertInput(mcnp, mode)
File “/usr/local/flair/flair.py”, line 1049, in convertInput
return convert.input(inp, mode, self.newLog(“flair”,“convert”),
File “/usr/local/flair/convert/init.py”, line 39, in input
return class(inp, name, log).convert(**kwargs)
File “/usr/local/flair/convert/convert.py”, line 130, in convert
self._convert(**kwargs)
File “/usr/local/flair/convert/convert.py”, line 295, in _convert
self.convertRegions(rotdefi)
File “/usr/local/flair/convert/mcnp2fluka.py”, line 524, in convertRegions
if " " in body:
TypeError: argument of type ‘float’ is not iterableThis
TypeErrorsuggests the converter was expecting a string but received a float, likely during region conversion.My Question: Could this error be caused by a specific MCNP syntax in my geometry definition (cells or surfaces) that the
mcnp2fluka.pyscript does not support?Thank you for any guidance you can provide.
Benson
