Dear Experts,
when I wanna to send my job to cluster (Slurm), Slurm return me this massage:
[prun] Error: Unable to access executable -> /usr/local/fluka/bin/rfluka
but I test fluka install and work correctly when I try this command line:
prun /usr/local/fluka/bin/rfluka -M 2 /home/rezaei/fluka_simulation/test_1/first.inp >>Batchfile.out
but I can not run when I use this script whit sbatch command:
#!/bin/bash
#SBATCH -J rezaei # Job name
#SBATCH -o job.%j.out # Name of stdout output file (%j expands to jobId)
#SBATCH -p p1 # Partition to be used: p1, p2, or pa (=p1+p2)
#SBATCH -n 1 # Total number of mpi tasks requested
#SBATCH -t 165:00:00 # Run time (hh:mm:ss) - 1.5 hours, Run time should be less than 168 hours!
#SBATCH --export=ALL
# Available paritions
# p1: support up to 96 MPI tasks, default partition
# p2: support up to 64 MPI tasks
# pa: support up to 160 MPI tasks, actually p1+p2
export PATH=$PATH:/usr/local/fluka/bin
export flukapath=/usr/local/fluka/bin/rfluka
export CURRENT_RUN=/home/rezaei/fluka_simulation/test_1
export NAME_RUN=first.inp
cycle=2
prun /usr/local/fluka/bin/rfluka -M ${cycle} ${CURRENT_RUN}/${NAME_RUN} >>Batchfile.out
Do you have any idea about this issue?
thanks in advance,
Mohammad
