FLUKA: 4-5.0
Flair:3.4.0
Operating system:
Compiler:
Dear Fluka team and experts
While using source_newgen.f routine, I get an error message as follow:
STOP Unable to open spectrum file (from .log file)
Abort called from sample_spectrum reason Unable to open spectrum file Run stopped! STOP Unable to open spectrum file (from .err file)
It seems strange because with same input (almost) I was able to run and use source routine by combination with a quite huge source spectrum file.
Here, the spectrum file is quite small (2 kB) sdc6p5em8.txt.dat (2.0 KB) and except the name set into the routine, nothing has changed.
source_newgenTdl1.f (19.1 KB)
I can also add that spectrum file, source routine, input/flair and fluka exe are in the same directory.
Joined are both the spectrum file and source routine. (input and .flair files are quite huge. But if necessary I can send it in a direct email).
Many thanks in advance for your kind help.
Jean-Baptiste
