pointsource.flair (1.7 KB)
pointsource.inp (1.1 KB)
Dear Experts,
I am trying to understand geometrical efficiency of a given detector geometry. In the file attached I am simulating a plastic scintillator of shape circular disk. I am using USRTRACK card in order to score fluence of particles passing through the detector volume.
The geometrical efficiency is defined as
=Number of particles falling on detector/ Number of particles emitted from source
I intend to integrate the fluence scored from USRTRACK card over all energies further multiplied by surface area of the detector. Since the fluence response is already per primary the value obtained should be geometrical efficiency.
Is my approach correct in order to obtain geometrical efficiency?
Thanks in advance.
