USBSCW Error Propagation
Hello,
I recently have been making use of the very convenient USBSCW command line tool that is included in fluka/bin. I was wondering, when adding several USRBINs with the same mesh geometry and everything, how is the uncertainty / error propagated? Is it added in quadrature, the maximum across the different inputs / cases, or something else? I couldn’t find documentation of it, though maybe I missed it. I could do a test case with a small number of bins, but at the same time there might be subtleties that could best be elucidated by an expert.
Thanks for your time and help,
Will
Glad to hear that you like it! (me too).
You are right about the specific documentation lack, but you can find its source code in fluka/src/tools.
The error is added in quadrature.
Ah perfect, thank you. It didn’t occur to me to check /src for the tools scripts, but on retrospect that makes perfect sense. And yeah USBSCW, has been invaluable for a project I’m doing with moving parts across multiple beam pulses! I wrote my own script at first for the plot.dat files, but this is way better.
Thanks for your time and help!
