Dear FLUKA users
I need to use fluscw.f routine to apply the photon and neutron fluence-to-dose equivalent conversion coefficients.
I am not familiar with the routines, so I seek help on what I should do to use this routine and apply these coefficients.
The fluscw.f user routine must be activated with the USERWEIG card in the input USERWEIG 0. 0. 3. 0. 0. 0.
(see the manual for details).
The template provided in <path to fluka>/src/user contains only these two instructions:
FLUSCW = ONEONE
LSCZER = .FALSE.
that mean ‘multiply the present scoring contribution by 1 (i.e. do not alter it)’ and ‘do NOT discard the present scoring contribution’ respectively.
In this routine, you can implement your fluence-to-dose equivalent conversion coefficients and assign the FLUSCW variable the corresponding value, which will be used right after by FLUKA to multiply the
scored fluence as a function of the particle id and energy (the input variables are documented in the header).
Additional relevant variables are contained in this include file include/usrtrc.inc in case you use USRTRACK scoring, in particular titutc identifies the detector name.
This fluscw.f (4.9 KB) contains a pseudo-code that you can use as starting point.
