Dear Experts,
I would like to create input files which differ by only a few input variables from each other and I want to use the method of FLAIR manual F3.6}, at the end of the chapter. It uses arrays and tuples to store the variables and a loop variable to identify them. The loop is initialised in the FLAIR RUN-tab, generating input files showing the changed variables.
When I try to start one of those generated input files, the run aborts and in the *.err-file I read
“Abort called from EXPREV reason NO MATCH FOR CODEWORD Run stopped!”
I added the flair project file(var-001.flair), the mother input file (var-001.inp) and one of the generated input files (var-001-2.inp), showing that the variables were indded correctly parsed and entered into the input file. When I delete or inactivate the #define-lines in var-001-2.inp, then it runs without error messages.
What do I overlook here ?
Thank you in advance for your insights, Thomas (@totto )
var-001.flair (1.9 KB)
var-001.inp (1.2 KB)
var-001-2.inp (1.2 KB)
