I was trying to define a vector as a variable
for which Flair seemed to accept and evaluate just fine.
However, when I tried to actually run it, I get the following error
Abort called from LFLPRP reason DEFINE 4TH FIELD IS NOT A COMMENT Run stopped!
STOP DEFINE 4TH FIELD IS NOT A COMMENT
I know the #define card with the vector definition is the problem because if I disable it, it runs like normal.
Is it possible to define vectors in with preprocessor variable?
