Without any ".fort" file and fluka_xxxx directory
WanB.inp (1.5 KB)
The attachment is my file ,it can be run with finished OK,but without any “.fort” file and fluka_xxxx directory generated(actually it exist during the running time,but disappeared when it finished running,only some .err/.out/.log files generated),could you tell me why and how to solve this problem?
Dear Xiong,
you don’t have .fort files because you didn’t specify the the Unit for the USRBIN scorings, so the results are printed in the .out file instead of the separate .fort files.
The fluka_xxx directories are removed after a successful run, whilst the outputs and results are moved to the parent directory.
