I’m trying to model response function of CdTe detector. To account for charge trapping inside detector I’m using Hecht equation by modifying energy deposition with comscw.f routine. To get the proper response I have to know the exact coordinate of interaction of the particle inside detector which leads to energy deposition. To get the exact coordinate of interaction I use Xtrack(1) value. The result of modelling seems good, but still I have some questions about usage of this value and comscw.f routine:
1). Is it appropriate to use Xtrack(1), Ytrack(1), Ztrack(1) as a coordinates of of the point of interaction of particle which leads to energy deposition?
2). When I use XA, YA, ZA as a coordinates of the point of interaction of particle the program does not account for Hecht equation, the the result of the modelling looks like comscw.f routine doesn’t exist at all. How to use XA, YA, ZA in a proper way, do they describe the point of interaction of the particle inside detector?
3).In case if question (1) is wrong how to get the coordinate of the point of interaction which leads to energy deposition for every particle inside detector including secondary particles?
I put my input file with comscw.f in the attachment. Since the server doesn’t allowed to upload comscw.f with it native extension, I changed it extension to ‘log’.
Indeed, the DETECT card was conceived to score energy deposition (on
an event by event basis and with optional trigger functionality) on a per-region
basis, i.e. regardless of the position. The XA,YA,ZA passed to COMSCW
in this particular case are -infinity (-AINFNT), preventing your logics block
from being active.
Note that in your problem (120-keV photons on CdTe) you’ll have two
contributions to your scored energy deposition:
Particles depositing energy along the step (electrons). For these
contributions you’ll have NTRACK=MTRACK=1 and you can pick up the end
position of the step from XTRACK(1),YTRACK(1),ZTRACK(1). Since energy
is deposited continuously along the step, it’s difficult to define or
agree upon the “point” where deposition happens. What you can do is
examine the length of the steps with TTRACK(1) or, probably more
pertinent for you in view of your Hecht law stuff, the difference
ZTRACK(1)-ZTRACK(0). If you see that ZTRACK(0) does not differ
appreciably from ZTRACK(1) and your weighting factor is essentially the same
for either Z, then the “ambiguity” should be irrelevant and you’ll be fine.
Particles (electrons AND photons!) dropping below threshold. For these
two particle species, energy is deposited on the spot, NTRACK=0 and
one would be tempted to pick up the position from
XTRACK(0),YTRACK(0),ZTRACK(0)… However, as per the comment in the
include file tracker.inc, when NTRACK=MTRACK=0, then the position and
energy are not stored in the TRACKR common. Taking {X,Y,Z}TRACK(0) is
therefore not guaranteed to provide the actual position. I now fail to
see an obvious way to bypass this.
As an alternative way to proceed, you could try intercepting energy
deposition events within the main entry of mgdraw.f via the DTRACK
variable and the drop below threshold event in entry ENDRAW in the
same routine. You could start e.g. by dumping the z coordinate and
the deposited energy to a file (weighted with your Hecht law) and
doing the post-processing (build a histogram) a posteriori.
