Cosmic neutron ray energy spectrum data calculation problem?
I simplified the computational model, using the air layer as the neutron source,the soil thickness is 6 m.The calculations were made using the cosmic neutron ray energy spectrum, but the resulting trend seems to be problematic.I can only calculate single-energy neutrons.
My calculations turn out to be such a trend:
The flux result trend of the relevant paper is:
How do I implement the following energy spectrum calculations?At the moment it seems that there is something wrong with the program.Please help me!
Cosmic.inp (2.9 KB)
cydnp.txt (7.2 KB)
source_spectrum.f (10.5 KB)
Fengfeng Xu
Thanks in advance!
Dear Fengfeng,
I could not reproduce your first plot, with the user routine you provided. Also, to make it run I had to remove the first line from the spectrum file.
Furthermore, what is the quantity of the second column? For me it seems, that the numbers are the values of a lethargy plot (dN/d(logE) = E*dN/dE), while the source routine expects dN/dE values.
With my assumption I get the following source spectrum:
neutron
Which resembles the ones on your second figure.
Dear Fengfeng,
more meaningful error messages can be found in the .out, .log and/or .err files, located next to the input file or in the fluka_xxxx directories.
In this case the problem is with the character encoding of the spectrum file. See:
Dear Fengfeng,
I don’t see any changes in your spectrum file or source routine, also the attached Flair project file has different plot settings compared to the figure you posted last.
For these reasons I couldn’t reproduce you last result.
My spectrum was scored immediately after the starting location of the neutrons, so that is maybe the reason you see a different result.
Dear Teacher David,
Dear David, your judgment is correct. I gained a lot from this exchange and thank you again.This post can be closed.
Fengfeng
