Dear experts:
I want to observe the relationship between dose and time,I use DCYTIME and DCYSCORE card.But no data acquisition for simulation results.When I use RADDECY card,I will report an error when I select Active in Decays(As long as I set RADDECY card, this error will always exist, not only this FLUKA setting).
Please FLUKA experts help to see if there is any problem with my settings.
Dear FLUKA experts:
For RADDECAY card,when I set the Decays option to Active or Semi-Analogue,the Flair error can’t run,if Decays option chose reste,the Flair can run.At first, I thought it was my setting problem, so I created a new decay input file,I just set the Decays option to Active or Semi-Analogue,and other parameters were’t modified.but the same error still occurred.
The error is as follows:
Started 2021.06.22 18:02:37 - Running: Decay
Dir: /home/lin/Works/FLUKA/Not finished/Decay
Cmd: /usr/bin/nohup /home/lin/Packages/fluka4-1.1/bin/rfluka -M 2 Decay
/usr/bin/nohup: Ignore input
I tried to run your input and it failed for me as well. An error file is generated (I believe your files should be named “Decay001.err”) which contains this message:
*** Predictions for residual nuclei production and ***
*** decays require the activation of heavy fragment ***
*** evaporation by means of the PHYSICS/EVAPORAT card ***
*** look at the manual and release notes for further ***
*** details ***
*** Execution terminated ***
The error is pretty clear: you are missing the card “PHYSICS” with the “EVAPORAT” sdum.
Have a look at the manual for the explanation on how to use it: PHYSICS | FLUKA
