Dose Rate Calculation for a isotope point source
I have created a Iodine-131 point source 0.5 m away from a NaI detector. I need to find the dose rate by Gamma emmision at NaI detector after certain time intervals. (1h and 24h ) I used DETECT card and got count vs Energy plots. Then I tried USRBIN, AUXSCORE and DCYSCORE. I got 0.000E0 values when I used RADDECAY in semianalogous mode. But with activation study mode and IRRADIATION card
I131Activity.flair (3.9 KB)
I131Activity.inp (4.5 KB)
Im getting some values at the output file I created with OPEN card. I would like to know whether Im on the right path with correct cards. INP file and FLAIR file attached.
Hello! Welcome and many thanks for posting your question on the forum. I will start to have a look at it as soon as possible. Please, stay tuned.
Hello! I had the chance to check your files. I suggest a gradual approach. Please find below some resources to help you address your problem gradually.
  • Approach to activation modes:
    • Activation in FLUKA: this lecture presents the set up of semi-analogue runs
    • Discussion on raddecay modes: this post and the FLUKA manual
  • Other topics on the forum
    • Other useful post: link
    • This discussion - which includes also the mentioning of TIME-CUT card
  • Scoring:
    1. DCYSCORE settings: the already mentioned activation lecture; in case of semi-analogue mode, DCYSCORE set to -1 is needed
    2. Post involving DETECT card, if needed
  • General comments:
    • I would place a simple USRBIN scoring mesh, even in AIR, and test the RADDECAY options/radioactive source simulations
    • Then, I suggest to increase the detail of the simulation bringing back the detector. What to score, then, will depend on your specific needs (is a USRBIN sufficient, or you want to collect info about the detector response).
    • I should also suggest to run with a sufficient number of cycles (“Recommendations”, page 29 of this lecture)
I hope to have provided you with sufficient resources to guide your solution. I will be away for work in the next to weeks, so further answers might be delayed.
Good luck with your simulation.
Tommaso
thank you Im getting results (dose rates) closer to the theoretical results I have.
