I am trying to install the latest version 4-4.0 on my MacBook (Sonoma 14.3.1). I have followed all the steps described in your website, but when I try to execute “make” on the terminal I get the following errror.
Thank you for your prompt reply. Apologies for my late response, I was trying to install FLUKA. I tried to install zlib from the link you provided but that did not fix the problem, I got the same message. I repeated the whole process but this time I installed gcc11 instead of gcc10. Do you think this will be an issue? It looks like it is installed now but now I have the following problems. When I type flair on the terminal I get this message:
Despite this message flair starts normally and I managed to run some very simple input files (its interface looks a bit different though, small and cramped). The problem now is that when I click on the geometry tab flair crashes and closes down.
From the OS version, I assume that you have an Apple chip. In that case, to compile FLUKA, you need at least gcc12, as indicated on the FLUKA website.
(We will update the information on the Flair website.)
For Flair, could you please provide the output of this command? port select --summary
I noticed a potential issue: you seem to be using the native Python instead of the one from MacPorts.
Typically, when you install MacPorts, the configuration file of your shell is updated to include the directories where MacPorts installs executables in the PATH environment variable. However, it seems that something went wrong.
In the same Terminal, try running this command first:
Thank you for your help. This actually helped, FLUKA now appears normal and it does not crash when I click on the geometry tab. I noticed however that in the dice tab some files are missing:
For DICOM, both Python 3.8 and 3.12 should work, but you need to install the Pydicom library as indicated in the Flair banner and on the Flair installation webpage for Mac.
(EDIT: Actually, for Python 3.12, I see that there is no corresponding port for pydicom yet. A solution would be to install pydicom via pip, but the simplest option is to downgrade the Python version as you did).
For the FLUKA error, please check the messages in the files *.out, *.log, and *.err."
Thank you for your help. Since I can run some files with FLUKA and it does not crash, I believe FLUKA and Flair are working properly now. So for now I will go this (maybe in the future I will get rid of Python 3.12 and try to reinstall everything).
I believe the FLUKA error has to do with the input files, I cannot understand from .out and .log files. Anyway if I cannot fix it I will create another topic regarding this error.
