I downloaded and installed the fluka library JEFF 3.3. I used the .deb file. I am running a simulation with 1 primary and this error apears:
ERROR: could not load neutron cross section for isotope Z=1 A=1 m=0
Abort called from KHPNLOAD reason Error loading neutron cross section for isotope Run stopped!
STOP Error loading neutron cross section for isotope
I am also using a LOW-WPXS card. (default). I provide my input file. What is going wrong? The /flukapath/data/neutron/JEFF 3.3 is installed, i can access it. reactpr new.inp (105.6 KB)
it looks like an issue with access rights/file location.
I would uninstall the deb package of the neutron library, and reinstall it using the tar file at the actual FLUKA directory (not in the /flukapath/… pseudo location)
