Material index in scoring LET, using GETLET function
As we have discussed before, it is possible to obtain both LETd and LETt by using the GETLET function, but that was only in a water phantom, where the material index of water is a fix number 26.
ENDLET = GETLET(JTRACK,EKIN,PLA,ZERZER,26)
When I want to score the LET in a CT DICOM file, where the assigned material in each voxel might be different, how could I use the GETLET function with a correct material index?
Dear @kwlibuaa,
Thank you for your question. To use the material of a certain region in the function GETLET you can use the function MEDFLK(MREG,1). It returns the material number as a function of the region number MREG. In this way, the material number is adjusted to each position where the function is evaluated.
I hope this helps.
Mario
