Dear FLUKA and Flair experts,
Following the discussion on the Marinelli Beaker source, I have reconstructed a Marinelli beaker model to simulate a uniformly distributed 40K source. However, the results I obtained are not consistent with the experimental data. To address this, I would like to replace the 40K source with a photon source emitting at 1460 keV.
The issue I am encountering is that, after modifying the beam using the BEAM card, the energy deposition scored with USRBIN changes significantly, as shown in the comparison between Figure 1 and Figure 2. Should I modify any settings in the source routine or adjust the input parameters in Flair to resolve this discrepancy?
Thank you in advance,
Matteo
marinelli.f (9.8 KB)
USER.flair (3.8 KB)
