I’m using Ubuntu 22.04 LTS.
I’m having an issue with the updating of Flair, there is some part of my installation that is broken for reasons I don’t understand. I tried first to use the method of updating via the repository (sudo apt-get update, sudo apt-get upgrade), and I get the following output:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
flair-geoviewer : Depends: flair (= 3.2-2) but 3.2-1 is installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
Running the attempted fix suggested does not work.
I removed both flair and geoviewer, then I tried to reinstall them:
mvandijk@mvandijk-VirtualBox:~$ sudo apt install flair
The following packages were automatically installed and are no longer required:
libflashrom1 libftdi1-2 libllvm13
Use ‘sudo apt autoremove’ to remove them.
The following NEW packages will be installed:
flair
0 upgraded, 1 newly installed, 0 to remove and 7 not upgraded.
1 not fully installed or removed.
Need to get 0 B/40.9 MB of archives.
After this operation, 73.8 MB of additional disk space will be used.
(Reading database … 267311 files and directories currently installed.)
Preparing to unpack …/archives/flair_3.2-2_all.deb …
Unpacking flair (3.2-2) …
dpkg: error processing archive /var/cache/apt/archives/flair_3.2-2_all.deb (–unpack):
trying to overwrite ‘/usr/local/flair/geoviewer.so’, which is also in package flair-geoviewer 3.2-2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I tried to use the .deb packages instead:
sudo dpkg -i flair_3.2-2_ubuntu22.04_all.deb flair-geoviewer_3.2-2_ubuntu20.04_amd64.deb
Selecting previously unselected package flair.
(Reading database … 267256 files and directories currently installed.)
Preparing to unpack flair_3.2-2_ubuntu22.04_all.deb …
Selecting previously unselected package flair-geoviewer.
Preparing to unpack flair-geoviewer_3.2-2_ubuntu20.04_amd64.deb …
Unpacking flair-geoviewer (3.2-2) …
dpkg: error processing archive flair-geoviewer_3.2-2_ubuntu20.04_amd64.deb (–install):
trying to overwrite ‘/usr/local/flair/geoviewer.so’, which is also in package flair 3.2-2
dpkg: dependency problems prevent configuration of flair:
flair depends on flair-geoviewer; however:
Package flair-geoviewer is not installed.
dpkg: error processing package flair (–install):
dependency problems - leaving unconfigured
Processing triggers for shared-mime-info (2.1-2) …
Processing triggers for hicolor-icon-theme (0.17-2) …
Processing triggers for mailcap (3.70+nmu1ubuntu1) …
Processing triggers for gnome-menus (3.36.0-1ubuntu3) …
Processing triggers for desktop-file-utils (0.26-1ubuntu3) …
flair
sudo dpkg -i flair-geoviewer_3.2-2_ubuntu20.04_amd64.deb
(Reading database … 268849 files and directories currently installed.)
Then I tried compiling from the tgz:
mvandijk@mvandijk-VirtualBox:~/software/flair/flair-geoviewer-3.2$ make
make -C viewer
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/viewer’
make[1]: Nothing to be done for ‘all’.
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/viewer’
make -C farm
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/farm’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/farm’
make -C geometry
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/geometry’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/geometry’
make -C data
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/data’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/data’
make -C graph
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/graph’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/graph’
make -C math
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/math’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/math’
make -C tool
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/tool’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/tool’
make -C xdraw
make[1]: Entering directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/xdraw’
make[1]: Leaving directory ‘/home/mvandijk/software/flair/flair-geoviewer-3.2/xdraw’
make: *** No rule to make target ‘/usr/include/tcl8.6/tk.h’, needed by ‘geoviewer.o’. Stop.
Any guidance on any of these methods would be helpful! Thank you,
Maarten
