mibauer
(Michael Bauer)
1
Hi,
approx. 2 weeks ago I set up lxflu_submit according to the explanation and tgz file at:
It worked fine and I ran several jobs successfully.
But since yesterday there is is problem: When I enter the command on lxplus like:
lxflu_submit example.inp -c 1 -n 1 -p 100 -j “espresso” -q --start
the command lxflu_submit is no longer found from my bash.
error message:
-bash: lxflu_submit: command not found
I redid all the steps from the README file in tgz but it still does not work.
Can you help?
Thanks,
Michael
mrettig
(Markus Widorski)
4
Hi Michael,
could you post the output of echo $PATH ?
Markus
(You can download the most recent version of the lxflu scripts here lxflu.tgz (40.1 KB) which include a number of changes. Check the readme file.)
mibauer
(Michael Bauer)
5
Hi Markus,
thanks for the help and sorry for my late reply.
echo $PATH gives me:
/cvmfs/sft.cern.ch/lcg/releases/gcc/9.2.0-afc57/x86_64-centos7/bin:/cvmfs/sft.cern.ch/lcg/releases/binutils/2.30-e5b21/x86_64-centos7/bin:/afs/cern.ch/atlas/scripts:/usr/sue/bin:/usr/lib64/qt-3.3/bin:/usr/condabin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/puppetlabs/bin:/afs/cern.ch/work/m/mibauer/private/pointWSig/run_on_condor/lxflu::/afs/cern.ch/work/m/mibauer/private/pointWSig/pathtofluka/fluka4-3.0.a2/bin
In my source file I have the following definitions:
export FLUPRO=/afs/cern.ch/work/m/mibauer/private/pointWSig/pathtofluka/fluka4-3.0.a2
export PYTHONPATH=/afs/cern.ch/work/m/mibauer/private/pointWSig/run_on_condor/lxflu:$PYTHONPATH
export PATH=$PATH:$PYTHONPATH
export PATH=$PATH:$FLUPRO/bin
as far as I can tell these go along with the description from the most recent version.
Thanks,
Michael
mrettig
(Markus Widorski)
6
OK,
can you check that the lxflu_submit file is placed under this path ?
Markus
mibauer
(Michael Bauer)
7
Thanks Markus,
indeed, that’s the iusse.
I moved the file from there at one point and didn’t think about changing the path variable.
Excuse me for taking your time for such a trivial issue.
Thanks again,
Michael
