Reason for the shift in the maximum of the energy deposition
I am doing some simulation with electrons impacting a sample in Carbon 10x10x3. I have observed that by increasing the impact angle I have a reduction in the maximum value of energy deposition and a shift of the maximum as well. Doing the same simulations with Tungsten I do not observe the same behavior. In tungsten increasing the impact angle the maximum tends to increase which is quite understandable. However, in the case of carbon, I am not getting the reason of the shift and the reduction of the maximum.
Lovepreet
Dear Lovepreet,
Apologies for the late reply.
We are looking into this post, could you please share your input file?
Marta
Dear Marta,
Thanks for your reply.
These plots are a result of different simulations run with different impact angles. I attached the input file with 5 and 15 degree impact angles for C and W, so you can check the differences. Please let me know if other input files are needed as well!
I hope to receive your answer soon!
Carbon_Scan1.inp (1.5 KB)
Carbon_Scan7.inp (1.4 KB)
Tungsten_Scan1.inp (1.5 KB)
Tungsten_Scan8.inp (1.4 KB)
Thanks
Lovepreet
Dear Lovepreet,
I see that you have defined a SOURCE card, could you please provide the source routine you are using?
Thanks
Dear Marta,
Please find attached the user routine.
WPTE_W.f (11.3 KB)
Thanks
Lovepreet
Dear Lovepreet,
Just a naive preliminary consideration: you appear to be shooting your beam almost grazing along the x axis. Is that what you really want? If by “impact angle” you mean the angle theta between the direction of incidence and the z axis, you’d need to put sin(theta) in WHAT(4) of BEAMPOS, and not cos(theta) as you appear to have now. Safely ignore if I misread.
Cesc
Dear Francesc
Yes, the angle is with respect to the x axis and indeed the angles are quite small. What I am not getting is the reason behind the shift of the maximum. Is it due to some mistakes in my script or is there a valid reason (maybe related to the dependence of the cross sections on the energy of the particles, the reactions that take place, etc.)?
Thanks,
Lovepreet
Dear Lovepreet,
Thanks for your feedback and for providing us with complete information to address your question.
For your question (~7 MeV e-) we can focus on a purely electromagnetic problem (e- and photon transport).
If you do a run with EMFCUT cards setting high production and transport thresholds for photons, you will still see the same behavior at shallow depths in the energy deposition spectrum as a function of angle, so we can safely ignore Bremsstrahlung photons for this discussion (they do matter of course for a quantitative analysis and to explain the tail in the depths of your geometry, but this is now not essential to address your doubt of the near-surface behavior).
We are then left with the electrons. The basic ingredients for e- transport at these energies are:
  • elastic scattering on the screened Coulomb potential of the target atoms (via multiple Coulomb scattering)
  • electronic stopping / delta ray production.
It’s now a matter of examining the (coupled) effect of both in your scenario.
Since electronic stopping scales with the target material density, you’d qualitatively expect the energy deposition profile to be much more compact for W (rho=19.3 g/cm^3) than for C (rho=2 g/cm^3). Indeed, here is the 2D energy deposition plot (USRBIN) for e- in the present exercise (slightly distorted since we forget about photons) in W and for C for 5-deg incidence with respect to the X axis:
W_5 C_5
The drastically different spatial extent of the 1D energy deposition profiles in your original post for W and C is then reasonably explained (the missing “skirt” dragging things down to deeper depths is mostly Bremsstrahlung-induced).
The next piece of information: elastic scattering scales with the square of the target atomic number. Thus, elastic scattering is a factor ~(74/6)^2 ~150 more effective in W than in C, meaning that the electron shower in W will promptly “lose memory” of the initial e- direction and will quickly exhibit an isotropic angular distribution after a modest traveled distance, hence the isotropic blob in the W plot.
Instead, since the cross section for elastic scattering is lower in C than in W, electron showers in C develop to longer distances before loosing memory of the incoming e- direction. Indeed, if you look at the blue/purple shades in the C plot above things are fairly isotropic, but in the early red/orange/yellow regions of the e- shower, the initial direction is still remembered (elongated feature retained instead of a promptly isotropic one).
Let’s look now at the 15-deg angle (with respect to the X axis) case for W and C:
W_15 C_15
Whereas for W the shape remains essentially indistinguishable from that in the previous plot, for C things are substantially different. Given the less effective elastic scattering, memory of the initial direction is retained for longer path lengths. This, combined with the lower stopping power in C than in W, implies that the e- shower subtends longer path lengths while still preserving a “blob” around the initial direction.
For 5-deg incidence, it turns out that the blob is “cut” still fairly symmetrically by the X axis, so you see a monotonically decreasing behavior in your energy deposition profile. For 15-deg, the “blob” is now fully
contained in your C, so the meat of the energy loss distribution shifts to deeper depths, hence the bump/maximum you witness.
In a nutshell: you’re seeing the combined effect of elastic scattering and electronic stopping, in a grazing incidence condition, which is sensitive to transverse details of the early development of the e- shower. Looking at a 1D distribution (along Z) only, one of course loses sight / valuable information in the other dimensions (X here), which give deeper insight.
I hope this qualitative explanation helps somewhat…
Cesc
Dear Francesc,
Thanks a lot for your detailed explanation. Indeed, it helps a lot.
Lovepreet
