Dear FLUKA users,
It is our pleasure to announce that a new minor release of the FLUKA code, FLUKA 4-2.2, has been issued and can be downloaded from the Official CERN FLUKA website.
See the release notes at the bottom of this message for a detailed account of all novelties. Many thanks to all users who reported the issues here addressed.
With our kindest regards,
The FLUKA developer team at CERN and collaborating institutes
=== Fluka-4.2.2 ===
PHYSICS IMPROVEMENTS:
Shell and pairing effects adjustment in the course of the IntraNuclear Cascade (already implemented since FLUKA 4-2.0).
A typo in the RELEASE-NOTES for FLUKA 4-2.0 has been fixed: the proton reaction cross section refinement for {63,65}Co should have read
{63,65}Cu.
BUG FIXES:
Fixed the unexpected behavior reported in this thread due to a spurious setting in the pre-equilibrium stage of FLUKA’s hadron-nucleus inelastic interaction module.
Fixed a rare crash reported in this thread due to a bookkeeping error for biased low-energy nuclear projectiles with A>2 on 2H in inverse kinematics.
Fixed the gamma double counting reported in this thread due to the attribution of decay products of 109*Ag to 109Cd too.
Fixed a bug which truncated multiple Auger-electron emission from radionuclides to a single one.
The offset of a magnetic field prescribed in the input card MGNCREAT now applies not only to field maps, but also to analytical magnetic fields.
A missing transformation matrix has been introduced to correctly apply the azimuthal angle prescribed in the MGCNREAT card.
Whereas in previous versions the MGNDATA and MGNFIELD cards had to appear after the MGNCREATE card to properly work, now they are position-independent.
A meaningful abort message is now written to the output file if no field data are given in case a 2D/3D field map is requested.
Fixed an incorrect region indexing in the magnetic field acquisition in case lattice indices started from a value different from 1.
Increased upper energy limit for stopping power tabulations so as to accommodate high-energy protons generated in relativistic ion collisions.
The source.f user routine now initializes the age variable (AGESTK) also in the case of radioactive-isotope decay, fixing the issue reported in this thread.
