Run Fluka with multiple cores
Dear @tianyukun ,
The way to run FLUKA in a parallel way (which in itself is a single-thread software so it does not support parallel processing) will depend on the system on which you are running, which operating system, are you running on a CPU cluster, … . I advise you to use the search bar if you can find information in addition to a number of posts on this forum which deal with this topic:
  • on optimizing memory or running on a cluster
  • Launching parallel FLUKA simulations without using Flair, each run with different name or in a separate folder, and with different random number. The post-processing will then also require a script or can happen in Flair.
Hopefully this can set you on the right path,
Andreas
