Hello, everyone,
I am struggling to get this simulation to run. In Flair I get the running message but the simulation seems to be stuck there. In the output files (after I kill the simulation…) no error is shown, this happens in other computers…
I am able to run other simulations in my pc.
The .inp file is attached.
Thank you.
Duarte
Simulacoes_Galaviz_fibra1mm.inp (16.3 KB)
Dear Duarte,
it seems that some body names in the input file are 9 characters long (such as detect8_2), while a body name can only be 8 characters long.
I hope this helps
Vojtěch
Dear Duarte,
there is actually another problem - given the large number of optical photon reflection and either no or very low absorption, the simulation goes into an infinite loop. I tried to increase the absorption coefficients of POLYSTYR and PMMA to 1 cm^-1 and the simulation is running at 3.3 seconds per primary. You should always avoid setting this factor to 0.
Vojtěch
Hello Vojtěch,
Thank you! That really helped!
Duarte
