Stop nonsense gas
I’ve done as you said. After correction of some errors there are shown the next one.
Abort called from DPDX reason NONSENSE GAS Run stopped!
STOP NONSENSE GAS
What’s that mena ? Here is corrected .inp file.
Photoyields.inp (11.5 KB)
Dear @sergey.a,
Specifically, the error message comes from the fact that you have defined a density of 160g/cm-3 for the compound “GRAVE”. It seems to be quite an heavy material.
Additionally, the “GRAVE” definition includes a spurious zero for its third component.
But what is more important to stress, is that your geometry is full of error. Just open in the the geometry editor and they’ll be highlighted. Be careful, the simulation may run, because you have overlapping regions, but the results are unrelaiable.
