I need help install FLUDAG.
The problem happens when I try to do “make” to build FLUDAG:
Linking CXX shared library libfludag.so
/usr/bin/ld: cannot find -lFLUKA_LIBRARIES-NOTFOUND/libflukahp.a
src/fluka/CMakeFiles/fludag-shared.dir/build.make:102: recipe for target ‘src/fluka/libfludag.so’ failed
make[2]: *** [src/fluka/libfludag.so] Error 1
CMakeFiles/Makefile2:1984: recipe for target ‘src/fluka/CMakeFiles/fludag-shared.dir/all’ failed
make[1]: *** [src/fluka/CMakeFiles/fludag-shared.dir/all] Error 2
Makefile:140: recipe for target ‘all’ failed
make: *** [all] Error 2
I’m not being able to solve it.
Help would be welcome. Thank you.
horvathd
(Dávid Horváth)
9 February 2021 15:59
#2
Dear Duarte,
I remembered that you already asked about FLUDAG in this topic:
Hello, Andy
From what I understand from your last response, FluDAG is not yet ready to be used ( or installed) with the new Fluka version, is that correct?
Thanks
Duarte
did you try to install from the linked repositories “fluka-cern” branch? The error message suggest the FLUDAG tries and fails to link a different version of FLUKA.
Hello, David,
I am trying to intall from the linked repositories you mentioned. I am using the latest version of FLUKA…
Thanks,
Duarte
makeclean
(makeclean)
17 February 2021 23:54
#4
HI Duarte
Just to be absolutely sure, you have checked out my branch from the repo. You must also set the appropriate FLUKA_DIR, command on the cmake line e.g.
cmake .. -DBUILD_FLUKA=ON -DFLUKA_DIR=/home/adavis/opt/fluka/fluka4-0.1/ -DMOAB_DIR=/home/adavis/opt/moab -DBUILD_STATIC_LIBS=OFF
I’ve just build from that branch against FLUKA-4.01 and it built fine, are you using a different version?
Thanks
Andy
Hello, Andy,
Thank you for your patience.
I am positive: I am using what I download from your repo and FLUKA4-0.1.
I tried setting the appropriate FLUKA_DIR and yeat I get the same error.
Thanks,
Duarte
horvathd
(Dávid Horváth)
26 February 2021 12:41
#6
Dear Duarte,
did you manage to install FLUDAG?
I was able to do so with FLUKA 4-1.1 following the guides from DAGMC’s official site: Installing dependencies — DAGMC and Install FluDAG — DAGMC
The only change I did was to replace the lines:
git clone https://github.com/svalinn/DAGMC
git checkout develop
with
git clone https://github.com/makeclean/DAGMC.git
git checkout fluka-cern
Hello,
I finally succeeded in installing FLUDAG. I had to do:
and I had to set the proper FLUKA path in the cmake.
Thank you both.
Duarte
