Dear Richard,
It is still not entirely clear to me what might be your problem, but I have a few considerations:
- I opened your
dualct2.flairfile and I found that theVOXELcard had a wrongfilename, I chaged it alternatively to the two.vxlfiles you provided (default.vxlandnewconver.vxl), however, also for me the voxel regions did not have a material assigned → there might be something wrong with both files. - Then I decided to create a
.vxlfile from scratch starting from a dicom example file that I found on the web (.dcm), to test yournewconver.matfile:-
first I used for the material definition
head.mat(a file provided in the Flair webpage, in section Auxiliary files) → this worked fine and created the desired geometry (see picture below)
then I used
newconver.matand in this case I got the same error message you are receiving (se picture below).
To me, there is something wrong with newconver.mat, but also probably with default.vxl and newconver.vxl.
Can you please try to re-generate your .vxl file starting from your dicom file and using, for the materials, head.mat (download it from the Flair webpage, in section Auxiliary files)? To create the .vxl file, I would suggest you to follow the steps provided in this thread: RT-planning example using Fluka.
I hope this can help you,
Marco
