Hello
I am a beginner and I am looking for a tutorial video or any example about RT planning using Fluka
Thanks in advance
Hi @saed
unfortunately there is no available tutorial. Briefly you have to do the following
- collect all DICOM files, preferably in a subfolder and even divided in subfolders for better organization.
You need to have at least the following modalities:
- CT scan
- RTDOSE
- RTPLAN
- RTSTRUCT
- Open flair
- Start a new flair project based on the voxel template
- Go to the Dicom tab of flair. If not visible you can find it on the drop down menu on top-right
- Click on Add and select the folder with all dicom files. You can optionally increase the depth from 1 to 2 or 3 depending on the nesting of the subfolders. Do not exaggerate, it can take time
- Select all the dicoms you want and click Ok
- Click on the CT: scan dataset then click on the Voxel on the ribbon, and finally click on the VOXEL to create the voxel file
- Click on the Card to update the VOXELS card of your input
- Select the RTDOSE: dataset. and click on the Card to insert the relevant USRBINs
- Select the RTPLAN dataset, Click on the RTPlan and button and then on the Create
- You are now ready to run. Edit the input to put the number of primaries you want and click Run
- When the run is finished process the Data as usual
- Go again to the Dicom tab, select the RTDOSE you added in the input.
- Click on the RTViewer, then load the USRBIN file you calculated, set the proper normalization and select the corresponding ROI to plot the DVH
