X and Y scale normalization in USRBIN plots
Hi, I wonder if it is possible to normalize the X and/or Y scales when plotting USRBIN results, for instance with the purpose of using mm instead of cm as length units. I have searched through the forum and the Gnuplot options but I have not been able to find a command for that, if it exists. I see that, if I understand it well, such an option is offered by Flair in another kind of plots by means of X norm and Y norm fields (Normalization of Y values in a USR-1D plot). Thank you in advance for your help.
Enrico
Dear Enrico,
unfortunately at the moment there is no built in normalization option for the X and Y axes for the USRBIN plots, but the following topic describes two ways to manually change them:
Dear Dávid, thank you so much!
Enrico
