Dear FLUKA Community,
I’m trying to develop the geometry in the attached input files. I have a block with two holes on it, which I would like to replicate using the lattice capabilities.
I think I’ve followed every recommendation so far: I enclosed the block with an “external surface”, which I use to create the replica regions. I create the first replica at the left of the first one, taking care that the external surfaces do not touch/overlap.
Strangely, the simulation in these conditions run, but the GEOEND Debug option shows a lot of errors, which I discovered after adding many blocks. So I returned to the primitive version, with only one block, and the errors are still there.
I haven’t been able to detect the problem, because the geoviewer does not show it, and the Debug option of the GEOEND card only gives me a lot of the following messages:
**** Flkldb: Geometry error found ****
**** The point: 1.7000000003887630 -10.399999999611236 0.58500000038876376 ****
**** is not contained in any region ****
**** ( Current cell: 1 Cell0001 ) ****
even though these points are (according to geoviewer and my understanding) included in a region.
If anyone could spot the error would be a lot of help.
I also have a question regarding the lattice capabilities: I would like to include a volume source in one of the holes of the block. Is it possible that, when I replicate the mother region, the holes in the replicas also work as sources? Or is lattice only a transport-related trick?
Thank you all for your time.
Federico
02-2021-flair.flair (3.3 KB) 02-2021-flair.inp (4.0 KB) 02-2021-flair001.err (122.1 KB)
